TO-20 won't start
Basswood
08-24-2004 10:07:37
I have a T0-20 that has been running great. It decided not to start the other day. Changed the coil and have a good spark there and at plugs. Seems to flood? Cleaned the carb also. Still does not start and smell of gas pretty quick. Please help - thanks much.
Mr Chapp
08-25-2004 18:40:47
 Re: TO-20 won't start in reply to Basswood, 08-24-2004 10:07:37
Check to see if the float is full of gas, thus sinking and letting too much gas into the intake. Don"t know if this is common with to, but it"s pleanty common on British engines. Good luck, have fun!!
gshadel
08-24-2004 13:40:39
just an idea on this... mayby your carb has flooded from gas leaking by the float/needle valve. Try this, pull the air intake off the front of the carb to make sure it isn't full of gas. Close the gas bowl shut-off valve and pull the drain plug on the bottom of your carb and let it drain. Make sure the shut-off valve is holding and not letting gas leak-by.
Put everything back together, open the gas shut-off, give it a minute to re-fill the carb, and try to start her up. Hope that's it!
