Front Counter Balance Weights
Gene Stevens OH
09-03-2004 04:33:43
I have use of a five (5) disk plow. It appears I need to add additional weight to the front of my TO-20 to maintain a straight line of cut. Any suggestions on adding the weifgt and how much to start with?
Gene Stevens OH - Tx
09-08-2004 17:54:44
 Re: Front Counter Balance Weights in reply to Gene Stevens OH - Tx, 09-03-2004 04:33:43
Went back to school for basic numbers. I did learn to count to eight. It has eight disks and it looks as if no adjustments can be made. Everything is preset. I do not know how to place a picture on here but can send one if needed.
marlowe
09-03-2004 11:27:35
is this going on when plow is in the ground?if so then your plows are out of adjustment first thing to look at is the landsides,is the plow toed in or out?.as old as the plows are they all can be wore
Bill Stanley
09-03-2004 09:57:15
 Re: I tied log to bumper. in reply to Gene Stevens OH - Tx, 09-03-2004 04:33:43
While cutting trees to big for the bush hog lack of steering began to annoy. No weight on the front end. Had a rope and chain saw. I simply cut two of the biggest logs that I thought could be lifted and tied them to the bumper/grill protector. Worked good until dark when it was realized the top log interfered with the headlights. One log is still on the tractor but secured in a better way. Looks goofy but it was a quick and cheap way to experiment. It would be a quick way to experiment with the amount of weight needed for plowing
Boss Hog
09-03-2004 07:16:11
I'd start with a couple of front wheel weights.
But after that, I think it would be trial and error.
