Timing TO20
Nickk
09-07-2004 16:06:09
When I tap the ignition and look through the hole at the flywheel, will the flywheel actually have the letters "DC" stamped on it? All I see is a 15 degree reading, a few marks, and what looks like a 20 degree reading but stamped much larger than the 15 degree mark. Is this the dead center mark?????
Thanks,
Nick
John (UK)
09-09-2004 10:24:42
 Re: Timing TO20 in reply to Nickk, 09-07-2004 16:06:09
I have the factory instructions for doing this if you want them...Mail me at fergusontractors at hotmail dot com
Gene Stevens OH - Tx
09-08-2004 17:37:51
Remove the cover below the timing hole. Clean and if necessary paint the timing marks white. Put the cover back on and set the timing. This will make it easier and only cost you a few minutes.
gshadel
09-08-2004 07:46:11
If your flywheel is like mine, you should have a scale stamped on the flywheel from about 0 to about 30 degrees or so. I found it hard to see the stamped lines, I made marks on my flywheel with a white paint pen so I could see the marks real good while running the engine and shooting with the timing light. You pretty much need the whole scale to check both the idle and full speed timing. Don't recall the exact timing range off hand, it is in the manual.
I recommend pulling the bottom flywheel cover off so you can see a big piece of your flywheel, then turn the engine so you can see the whole scale, so you know what you are looking for when you set the timing thru that little hole.
good luck
steveormary
09-08-2004 15:34:18
 Re: Timing TO20 in reply to gshadel, 09-08-2004 07:46:11
Broke starter nose cone twice on my TO-30. Read a comment that the break could be caused by engine being out of time. Got a professional assistant(friend)to help and we timed it by the book.I&T manual. Had no trouble after that.
steveormary
