Question about Marvel-Schebler Carb on TO20
Mikews1
09-12-2004 17:47:33
I've got a '51 Ferguson TO20 with a Marvel-Schebler carb (model number TSX361). The carb needs to be rebuilt and the float has some gas in it. While doing some internet research I found rebuild kits for models TSX361 and TSX361A. Tractor Supply Company has a rebuild kit Fergsuson TO20's but the package says it's for Marvel-Schebler TSX361A carbs. So, here's my question: Will a rebuild kit or float for a TSX361A carb work on a TSX361 carb? What's the difference between a TSX361 carb and a TSX361A carb? Thanks in advance for your responses!
danct
09-13-2004 13:20:58
 Re: Question about Marvel-Schebler Carb on TO20 in reply to Mikews1, 09-12-2004 17:47:33
mike
the repair kit for the 361 is the same as for the 361a,the float assembly is also the same .Where the difference lies is in the carbureter body assy and the trottle body and shaft assy,but this shouldnt cause any concern for you.I think the 361 was superseeded by the 361a,but i cant tell them apart and ive worked on both
good luck
Danny
Mikews1
09-14-2004 18:08:44
 Re: Question about Marvel-Schebler Carb on TO20 in reply to danct, 09-13-2004 13:20:58
Danny,
Thanks for the info! It helped me a lot. I can order the rebuild kit now without having to worry about if it will fit or not.
Mike
