3 point lift problem
Barry from Stir
09-21-2004 05:43:16
Good Morning Everyone
Last night while bush-hogging some old feilds, I noticed that the hog was not looking right. It looked like it was on an angle when I was going straight. I looked down and where the lift arm goes into that ball bearing thing beside the back axle.( Sorry thats the only way I know how to describe it ) It has come off. I thought " OH BOY " this is serious. I couldnt lift the hog to get it back to the house so I just towed it. Once I got the tractor back I had a chance to get down and have a look. The bolts that hold that pivet point ( if thats what you call it ) were very loose. have I confuzed you yet? I took the lift arm and a hammer, grabbed the lift arm and hit it a swat, it went right back on. I notice that the lift arm had a small inner peice of the circle missing and thats why it poped off. Can any body tell me what I need to do to get this fixed
Thanks Barry
marlowe
09-21-2004 19:39:04
 Re: 3 point lift problem in reply to Barry from Stirling, 09-21-2004 05:43:16
my lift arms were wore out on the ends so i was going to replace the ends but thy cost more then the hole arm from our fleet farm. they are NOT as good as oem but thy do work and are like 28.00 u.s. each. tractor supply also has them same as used on fords
Barry from Stirling
09-21-2004 05:56:14
One more question, are the ball bearing things on the end of these lift arms part of the arm itself?. Maybe all I have to do is buy a new lift arm? Im thinking outloud now. I will await comments. Thanks again everyone,,, Barry
John (UK)
09-25-2004 14:53:37
 Re: 3 point lift problem in reply to Barry from Stirling, 09-21-2004 05:56:14
The balls are are part of the lower link arm. You can buy weld on parts to replace these but I have always felt that they are not as good as the originals due to the metal being heated and they wont be as hard so they bend (ferguson steel is hard as you know) It was always said by the factory NEVER to oil these balls as they collect grit and they will wear, same goes for the top link and front axle pin.
danct
09-21-2004 08:06:58
barry
i think your problem is just a worn ball on the end of your lift arm ,these can be cut off and a new piece welded on in its place ,however ,do not hammer too much in the area of the pivot pin ,this is the one with the castelated nut on it ,if you have to take the axel trumpet off you will regret having used a hammer on it ,im speaking from experience here
good luck Danny
