What I'm about to say works for a Continental engine, but it sounds like it will work on your Standard engine too. I have used the hammer and wood approach. I have also used the puller approach. Both work, but I'm here to tell you, the puller makes for a lot easier, more fun, job. You can literally pull all 4 sleeves while sipping on a beer! I tried using a 3# slide hammer from the top before, wasn't working for me. Tried jacking the sleeves out from the bottom using a floor jack, didn't work for me either, just lifted the whole tractor front end off the ground.I made a puller from a piece of 3" pipe to sit over the sleeve and threaded rod thru a piece of 3/16" steel plate on top the pipe, and on the bottom of the sleeve, with a nut on each end. The plate for the bottom can be oval cut, like one of the other posts, or cut round to about the same OD as the sleeve and slid in place past the crank. I don't have a way to machine a lip on the bottom plate to keep it centered in the sleeve, I cut a metal strip from steel plate and ground the edges to fit the I.D. of the sleeve and epoxied that strip onto the bottom plate give it a "lip" to keep the bottom plate in place. Tighten the nut, pull the sleeve right out. Worked like a charm. I saved my contraption for my "next" project tractor. If you try the pipe idea, make sure the pipe is cut square on the ends and sanded smooth so you don't damage the block. Good luck!
