TO 35 gas tank..................
RonW
09-26-2004 22:26:11
Does anyone know the exact capacity rating of this tank. I believe the year to be 1957. Thanks, RonW
Paul in AZ
09-27-2004 15:11:55
 Re: TO 35 gas tank.................. in reply to RonW, 09-26-2004 22:26:11
Ron, the tank holds 13.9 gallons, including a reserve of 2 gallons. Normally you open the fuel valve about two full turns. To access the reserve you open the valve all the way. Hope this helps.
Paul
RonW
09-28-2004 17:48:27
  Paul, thanks much. That helps me out. n/m in reply to Paul in AZ, 09-27-2004 15:11:55
muttonman
09-27-2004 17:31:08
 Re: TO 35 gas tank.................. in reply to Paul in AZ, 09-27-2004 15:11:55
Does a TO20 have the same reserve capability? I ran mine out of gas a while back. (stupid I guess, didn't check fuel) It would have been nice to drive back to the house instead of walking.
Paul in AZ
09-27-2004 22:10:42
 Re: TO 35 gas tank.................. in reply to muttonman, 09-27-2004 17:31:08
The TO-20 tank holds 10 gallons. The owner manual says this:
"Valve has a left-hand thread. Turn fully to the right (clockwise) to shut off the fuel supply. Turn fully to the left to opern main fuel supply through the standpipe which extends approximately one inch above the tank bottom. The reserve supply contains approximately one gallon which is released by turning shut-off valve two complete turns to the right from the full open position, thus opening the reserve fuel line which is flush with the bottom of the tank."
Paul
