Novi Ball type governor
Nickk
09-29-2004 14:06:47
Question: When installing the new Novi ball governor after the timing gear, what holds it in place? The manual says 4 bolts but I'm assuming they are referring to the other type governor. Do I just slip it on the camshaft after the timing gear and tighten it up with the camshaft nut? One other thing..... .Do I just slide the governor cup assembly back on the camshaft and rotate it so the tab will line up like it shows in the manual and meet the internal governor lever mounted in the timing cover???
Thanks in advance,
Nick
