1952 TEA 20 Transmission/Hyd Oil
G.K.
09-30-2004 17:01:59
I have the original tractor service instruction book for this tractor. The recommended lubricant for the trans/hyd/rearend is as follows:
above 40 F Shell SAE 50 or Essolube 50
below 40 F Shell SAE 40 or Essolube 40
Is this what is commonly being used or is some type of tractor hyd oil being used today? I have tried lighter hyd oils but all the seals leak. Gear oil 80w90 is too thick and does not work well in winter. Any suggestions???
John (UK)
10-01-2004 12:19:18
 Re: 1952 TEA 20 Transmission/Hyd Oil in reply to G.K., 09-30-2004 17:01:59
There is plenty of information about this question on here if you look in the archives. As long as it is GL1 like Jim says and not cheap motor oil with detergent in it. if it has detergent in it it carries all the crud round the system and wears the pump and any bearings away eventually. (sooner rather than later)
toolman
10-01-2004 00:16:23
not sure where your at but im in canada and i use durtran from petro can, run it winter and summer works well for me and has for years.polw snow all winter and the usual stuff all summer.
Paul in Ms
09-30-2004 18:23:49
Here in the States we use gl-1 in the old Fergusons.
Jim W
09-30-2004 19:02:18
 Re: 1952 TEA 20 Transmission/Hyd Oil in reply to Paul in Ms, 09-30-2004 18:23:49
There is oil that is for use in combined transmission, hydraulic, and differential applications like this, known as TDH. It's about the right weight. The key as mentioned is to be sure it's GL1, which has no additives harmful to brass parts. GL5 is to be avoided. Jim
tractorfix
10-01-2004 03:06:18
 Re: 1952 TEA 20 Transmission/Hyd Oil in reply to Jim W, 09-30-2004 19:02:18
I,ve always used cheap 10W30 motor oil in mine with no ill effects.
