Ferguson Type 14-AO-28 Plow (SN69637)
Gene Stevens
10-04-2004 12:16:51
Does anyone have a parts list for this two bottom moldboard plow? I have a friend that has a Ferguson 14A SN42963 two bottom moldboard and I can not see any difference between them other than mine could use some additional parts like the drag (?) wheel. I have used other similar plows without this attachment and did not have any problems. Thanks
John (UK)
10-04-2004 15:13:33
 Re: Ferguson Type 14-AO-28 Plow (SN69637) in reply to Gene Stevens, 10-04-2004 12:16:51
That "drag" wheel as you call it is really a rolling landslide. To stop the plow pulling to the unplowed ground you need a long lanslide but because this will prevent a fairly quick entry into the ground they fitted this spring loaded rolling landside that allows it to penetrate the ground more quickly than with a fixed type. It was an option on most ploughs that Ferguson made
