TO-30 Traction
Big Yarber
10-17-2004 17:20:40
When I pull my Harry Ferguson TO-30 i never seem to have near the amout of traction i need. the rear wheels have fluid in them. i was wondering if they made a wheel weights or if anyone had anyother ideas on how to fix my traction problem. thanks
John (UK)
10-24-2004 06:43:09
 Re: TO-30 Traction in reply to Big Yarber, 10-17-2004 17:20:40
Yes they do make wheel weights for all that type of wheel. One of the biggest mistakes made by operators is trying to go too fast when using ground penetrating implements, too much power can give you too much slip. The ideal engine speed is between 1/2 and 3/4 throttle and it will improve the fuel ecomomy too. It was never designed with the intention that it would be running at full throttle all day.
Scott Morrow
10-22-2004 22:28:31
They weigh 150lbs each total 300lbs I have a set on my To 30 with fluid it will out pull my To35 with just fluid. I would like to get 150.00 a set have two sets to sell. 920-373-6336. I will be going to Peoria Ill today the 23rd from there to Lansing Mich on sun staying in South bend Ind. I will put a set in the truck just call my cell.Scott
Scott Morrow
10-18-2004 06:27:18
I have 3 extra sets of ferguson rear weights they mount inside the fenders they are 150lbs each I am going to bloomington ill and up to lancaster mich this weekend are you close.
Greg / Indy
10-20-2004 14:01:58
 Re: TO-30 Traction in reply to Scott Morrow, 10-18-2004 06:27:18
Scott I am interested in a set also
Boss Hog
10-19-2004 04:24:29
If you're going up I-55 near Springfield, I'd be interested in a set.
I work about 100 feet off I-55 at exit 60. (Carlinville exit) My email at work is truss (at) wamusa.com
Big Yarber
10-18-2004 08:08:40
150 lbs a set or 300 lbs per set? how much are they worth? im located in urbana, ill (Northern At U of I) or mascoutah, ill (Southern at Homestead)
Big Yarber
10-19-2004 07:23:39
 Re: TO-30 Traction in reply to Big Yarber, 10-18-2004 08:08:40
my email is yarbs_07@yahoo.com or nyarber@uiuc.edu
Boss Hog
10-18-2004 06:04:13
Pulling what?
Like tractor pulls, pulling a plow, or ???
Big Yarber
10-18-2004 08:05:10
 Re: TO-30 Traction in reply to Boss Hog, 10-18-2004 06:04:13
tractor pull
