Harry Ferguson serial number
Normand Richard
10-17-2004 20:02:33
I'm trying to determine what model of Harry Ferguson tractor I bought recently. The serial plate is missing on the steering column. I assume it is a TO30 based on the location of the oil filter which is on the right side of the engine. Is there another serial number location? There are several numbers which are on the engine block, side of steering column and on rear axel, but which one if any is the model serial number?
Thanks for your help,
Norm
Paul in Ms
10-18-2004 04:40:52
 Re: Harry Ferguson serial number in reply to Normand Richard, 10-17-2004 20:02:33
If the oil filter is on the carb side the serial number for the engine will be in front of the starter with z129 prefix. Then you should have a to-30. All the other numbers are casting #.
