what size tractor do i have
norm wampler
10-23-2004 05:01:39
i just purchased a ferguson tractor and im not sure what size it is. could anybody out there help me figure out what it is? the serial # is 16722. there is a plate on the motor but it is unreadible. there are some raised letters on engine block that start out with Z120 and some other letters. it also has a lever on the side by your feet that takes in into high and low range. any help would be greatly appreciated, thanks , norm
Paul in Ms
10-23-2004 06:35:46
 Re: what size tractor do i have in reply to norm wampler, 10-23-2004 05:01:39
The z-120 engine is for the te-20 and to-20. These did not come with high and low trans so that is an add-on which is good to have. There should be a to or te prefix to the serial #
NORM WAMPLER
10-23-2004 07:13:38
 Re: what size tractor do i have in reply to Paul in Ms, 10-23-2004 06:35:46
you were Right, its a TO-16722, DO YOU KNOW WHAT H.P. IT IS? THANKS, NORM
Paul in Ms
10-23-2004 08:04:06
 Re: what size tractor do i have in reply to NORM WAMPLER, 10-23-2004 07:13:38
Depending on who you talk to the hp is 20 to24. Yours is a 1950 model. I have the same. It will do anything you need done.
John (UK)
10-24-2004 06:06:22
 Re: what size tractor do i have in reply to Paul in Ms, 10-23-2004 08:04:06
Nebraska test 392 shows this engine in a TE20 to have 24.02 Belt horse power
