35 3point lift problem
orod
10-23-2004 07:47:27
3 point hitch works when cold, stops lifting after warmed up, sometimes drops when clutch pedal pressed. any help appreciated
Big Dean
10-23-2004 10:05:17
 Re: 35 3point lift problem in reply to orod, 10-23-2004 07:47:27
You have a leak in the system in most cases I have found it to be the pump control valve. that problem is usually a sign it is time to rebuild the pump. To check for a leak on the top side get the oil up to normal operating temperature drain the oil down below the bottom bolt of the access plates remove the access plate with the Tran/Hyd dipstick in it on the right side try to lift something watch inside for oil leaking from the top if you have a lot leaking from the top you have a cylinder problem. Look for heavy turbulence near the right rear corner of the pump that is an indication of a bad relief valve. If you do not have one of those problems it probably is the control valve it is in the bottom of the three point pump. If I can be of further help Email me
orod
10-23-2004 19:02:09
 Re: 35 3point lift problem in reply to Big Dean, 10-23-2004 10:05:17
Thanks for the info, I"ll let you know how it goes. orod
