Sure Seals
Big Al
11-14-2004 06:04:10
I would like to know if I use sure seals do I need to replace the inner and outer seals on a TO-30
Mike Mohrhauser
11-17-2004 08:05:37
 Re: Sure Seals in reply to Big Al , 11-14-2004 06:04:10
What you wiil need for your TO30 is the Speedy Sleeve. It fits over the worn grove on the axle.
Big Al
11-14-2004 06:20:40
Also I was wondering how many have used Davis Tractor and how there service and quality is Thanks
killbilly
11-14-2004 07:26:34
 Re: Sure Seals in reply to Big Al , 11-14-2004 06:20:40
i tried installing sure seals in my to30 this summer and it didn't work out. the 30 has an inner and outer axle seal and the sure seals interfere with the inner seal. some people advertise sure seals for to30's but i think they were designed for the ford guys and might work ok on a to20 but not a to30. this has been my experience with them.
Ralph-Mich
11-14-2004 09:18:46
 Re: Sure Seals in reply to killbilly, 11-14-2004 07:26:34
Had ordered from Davis Tractor in the past .Good company. Just placed order for Radiator TO-30 for 53 furguson. Will respond on quality when it arrives 11-16-04
Ralph-Mich
11-17-2004 17:28:34
 Re: Sure Seals in reply to Ralph-Mich, 11-14-2004 09:18:46
BigAl, just received my new radiator from Davis Tractor fits like a glove. I had ordered 2 previous rads from my local supplier bad fit on the shroud. Martin Christian mentioned Davis Tractor on this site.Thanks to Martin my radiator problem is solved
Volfandt
11-14-2004 18:44:29
I installed aftermarket steel/rubber seal"s on my TE20 about 12 yrs ago and I"m pretty sure they were the sure seals. The axel slid right through them without having to do any major bearing R&R. Was concerned the bearings would wear out since the sure seals blocked oil from getting to them so I packed them with some auto bearing grease and they seem to be doing fine. I haven"t had a drop of oil on the brakes since. Brakes had never worked very well before and after I stopped the leaks and redone the brakes I can spin the TE20 on a dime, to either side!
Volfandt
