PTO Shaft
Big Al
11-17-2004 14:47:29
I have the one and one eight shaft with the one and three eight adapater My Question is how do I get the adapter off the original shaft
Big Al
11-18-2004 05:12:20
 Re: PTO Shaft in reply to Big Al, 11-17-2004 14:47:29
Thanks I cleaned the grease out and found the pin.
Jerry/MT
11-17-2004 18:50:33
I believe my 1-1/8 to 1-3/8 adapter is the factory original and it is held on with a roll pin that you drive out with a punch. I have seen them held on with a 1/4 " bolt. If you have a 1-1/8 to 1-3/8 ORC, the roll pin is hidden behind the grease fittings or there is a spring loaded pin on the outside that you push in as you pull out. It just depends on the kind you have.
Dale in WV
11-17-2004 17:01:02
Hmmm. Mine had an over run clutch -- had to take off the grease fitting on one side and a screw on the opposite side and then drive out a pin. Most likely some sort of hidden pin that way...That what you got?
Nickk
11-17-2004 17:37:33
 Re: PTO Shaft in reply to Dale in WV, 11-17-2004 17:01:02
Mine had a pin hidden behind the grease fitting also. I bought the 1-3/8ths spline shaft for my TO-20. Easy fix. Shaft was about $110.00 I think.
Nick
