Gearbox to Backend Drive coupling moves
Barry F
12-10-2004 13:39:42
I have just refitted the gearbox on my TED 20 Ferguson to the backend after replacing the gasket. The problem i have is with the splined tube which couples the gearbox output shaft to the differential input/pinion shaft. When i reach in to the backend with the PTO Lever "port hole" cover removed, i can slide the coupling tube forwards and backwards by 0.25 - 0.5 inch, is this normal? have i missed something during reassembly? the transmision seems to turn over by hand OK with one wheel jacked up. I would be grateful for any help you can give me.
Thanks
John (UK)
12-11-2004 11:21:48
 Re: Gearbox to Backend Drive coupling moves in reply to Barry F, 12-10-2004 13:39:42
There will be some end float in this drive tube and it will vary from one tractor to another. Unfortunatley it is not a shear tube like the later models.FE35 onwards.
Thomas
12-10-2004 14:45:47
It's called the shear tube, it's there to protect the transmission from excessive shock load. Movement is normal
Little Dave
12-10-2004 14:06:18
Barry I have my TO-30 lift arm cover off and I think the driveshaft just floats on the splined shafts in there because mine is the same way. Dave
