S.M.V. Placement on TO-30?
newbe
12-30-2004 20:51:40
I have been trying for a while now to find a place to mount a S.M.V. triangle on a to-30 but am not having very good luck. Surely somebody out there has one mounted or has seen one mounted on a to-30. Anybody have any input on where they mounted it or if a bracket is available someplace. Thanks for any input.
Fred Martin
01-05-2005 12:43:06
 Re: S.M.V. Placement on TO-30? in reply to newbe, 12-30-2004 20:51:40
I made a bracket that comes out from the light on the rear fender. It is made out of light angle iron and has two holes in it which bolts the SMV emblem to it. If it doesn't hit any of the implements when you lift them up...you have it properly engineered.
PS theres another piece of the same angle iron coming out from the bottom light bolt welded to the top one to kinda brace it. Fred OH
Gerald J.
12-31-2004 10:52:24
Visible from the rear is most important. I have them bolted to the back of the seat on my tractors. I recall there was a tapered socket bolted to the back of the spring cover on my MF-135 before that seat broke. Now the SMV is screwed to the back of the seat that I put on in replacement.
Both my tractors have a flashing amber light on the left fender. One could put the SMV emblem on the right fender, above or below the fender.
Gerald J.
