Float Level Setting (TSX 458) TO-30
Sodbuster
01-15-2005 13:37:06
Float level should be set at 9/32. After inverting top half of carb, would you measure from the gasket to the rear (big end) of float(s), middle of the float or to the little end of float (front)? Specs also gives a fuel level of 15/32. I assume this is saying that if the float level is correct, this would be the level of fuel in the bowl. (Getting old, can't remember)
John (UK)
01-15-2005 14:00:39
 Re: Float Level Setting (TSX 458) TO-30 in reply to Sodbuster, 01-15-2005 13:37:06
At the front, furthest away from the hinge. I think you would be correct with that level. Don't worry about getting old and forgetting things, I think most of us do that....lol
Sodbuster
01-15-2005 16:04:04
 Re: Float Level Setting (TSX 458) TO-30 in reply to John (UK), 01-15-2005 14:00:39
Thanks John, been a big help. (Also, thanks for the encouragement, guess I'm not in the boat alone).
John (UK)
01-16-2005 06:27:22
 Re: Float Level Setting (TSX 458) TO-30 in reply to Sodbuster, 01-15-2005 16:04:04
You are DEFINITLEY NOT alone in that....lol and I speak with great experience of it as well it seems to be getting worse too.
