TO 20 Draw bar ??
BL
01-23-2005 19:02:37
I was wondering why these little TO20s did not have a draw bar? I'm needing one for a TO and tought I would try one off a Ford. Will this work and what is the differance?
Jerry/MT
01-23-2005 19:08:22
 Re: TO 20 Draw bar ?? in reply to BL, 01-23-2005 19:02:37
If you mean the drawbar that mounts on the 3 point hitch and has a series of holes along it's length, yes it fits any catagory 1 three point. If you are talking about the drawbar that 's mounted on the transmission case, I'm not sure if the Ford one will fit the TO-20. But you can get one that does.
steveormary
01-24-2005 10:12:51
 Re: TO 20 Draw bar ?? in reply to Jerry/MT, 01-23-2005 19:08:22
BL
All we ever used on our Fords and Fergusons was the cross drawbar. If you use this drawbar you will need the braces that go from the drawbar up to where the top link fastens.These braces should be adjustable. You also need to lock the draft control lever in the down position. Also have the pto out of gear unless you are pulling pto driven equipment.Pto driven manure spreader comes to mind.
steveormary
steveormary
