1) TO-30 Rear drive gears and 2) A list of Ferguso
Mike Presley
01-31-2005 18:09:53
I'm in need of the main drive gears for a TO-30 rear end. The ones for my tractor are missing completely (taken out by a previous owner for replacement and never heard from again!) Also, am interested in a list of all Ferguson factory supplied or endorsed implements. I have a belly mounted, hydraulic lift, front dozer blade on mine that appears original and I would like to confirm that.
Thanks in advance.
SALTY
02-02-2005 15:00:14
 Re: 1) TO-30 Rear drive gears and 2) A list of Fer in reply to Mike Presley, 01-31-2005 18:09:53
Mike,
I got my parts tractor in out of the cold today! I do have the entire differantial unit including the two axle housings and the left axle still intact! The pto shaft is gone! Email me direct at resden@tcei.com with your needs and we will go from there! I am located 60 miles north of Milwaukee - where are you at?
Dennis
SALTY
02-01-2005 11:35:47
MIKE,
I have the entire rear end here from a TO 30 parts tractor. I"m sure whatever gears you need are in there. I would have to take them out(once I dig it out of the snow)! Let me know exactly what you need and I can go after them!
Dennis
John (UK)
02-01-2005 14:49:05
 Re: 1) TO-30 Rear drive gears and 2) A list of Fer in reply to SALTY, 02-01-2005 11:35:47
Make sure thatthe axle-shafts are the same, early ones had 16 splines later ones had 19 it should have 19 in that tractor but some kind person may have changed the rear end, as they do.
