what is this for?
Art Hughes
02-05-2005 20:29:48
There is a steel rod about 12 inches long with a heavy spring around it projecting from the back of the housing the seat is mounted to. What is this for? Tractor is a 1950 TO20.
Thanks
Paul in Ms
02-06-2005 04:27:28
 Re: what is this for? in reply to Art Hughes, 02-05-2005 20:29:48
This is the top link for the 3 point hitch. It is also the main part for the draft control when you use a plow. The big spring is called the control spring which is compressed with the upward pressure from the plow which in turn helps controls the depth of the plow in the hard ground. Which is the draft control.
