oil pump
Alex C
02-27-2005 19:16:17
I own a TEA-20....
Do I need to prime the oil pump if it has been removed or can I just reinstall and it will work??
Thanks, Alex
Jerry/MT
02-27-2005 19:20:51
 Re: oil pump in reply to Alex C, 02-27-2005 19:16:17
I'm not sure how you would prime it since it is driven by the timing gear. Just make sure that the pick up tube has any of the seals seated properly and has no cracks in it.
John (UK)
02-28-2005 08:12:59
 Re: oil pump in reply to Jerry/MT, 02-27-2005 19:20:51
There is no need to prime the oil pump, just make sure that you check everything that has been said already about the pick-up pipe etc. and when you assemble the pump make sure there is plenty of oil in the pump parts to start with, when you come to start the engine, turn it over a few times first so the pump will start without the engine actually running.
Alex C
02-28-2005 15:01:11
 Re: oil pump in reply to John (UK), 02-28-2005 08:12:59
Thanks John
Alex C
02-27-2005 19:39:18
Thanks Jerry...
I'm not sure either....I have heard of priming an oil pump after a rebuild and wasn't sure if I needed to worry about it.
Alex
Jerry/MT
02-28-2005 17:50:06
 Re: oil pump in reply to Alex C, 02-27-2005 19:39:18
On car engines, the oil pump is usually driven off the distributor drive (at least they used to be. Don't know about these modern engines.) and you could prime them with an old piece of distributor shaft and an electric drill.
