CT Carb Kit WARNING!!
NealIN
04-28-2000 05:03:55
I recently rebuilt the carb on my TO-20 using a complete rebuild kit from CT, now Quality (ha), and after installing the carb have been fighting a lean mixture problem. After replacing the entier fuel system including the sediment bowl assembly and spending a lot of time playing with other things I finally tore down the carb again.
Fortunately I kept all the old parts from the carb because what I found was that the new jets were wrong. The new main jet had an orifice the same as the original idle jet and the new idle jet orifice was much smaller than the original.
I checked the kit part number against the catalog and it is correct. So my assumption is that either I got a bad kit or they are all bad.
Neal
