Front Weights
Alex C
03-02-2005 19:14:39
I was wondering if anyone out there has ever successfully attached a braket for weights on the front end of a TEA20 etc.....I'm sure I can install the bracket but I'm not sure if the front end can handle the added stress.
Willy-N
03-02-2005 20:36:19
 Re: 200 lb Front Weight in reply to Alex C, 03-02-2005 19:14:39
third party image
I made a bracket for under the TO-30 Ferguson. The Axle mount has 3 drain(?)1/2 inch holes in the bottom. I used these holes to mount a 6 inch Chanel Iron Mount with 2 recever hitch boxes welded on the ends to slip my bumper into. One bumper was made out of just chanel steel the other one was chanel steel with a section of 6 inch bar stock weighing 200 lbs. Depending on the needs I could slip in what ever one I needed easily. Never had a problem with the set up and it was not hanging off the Pivot Pin on the axles moving around. Picture shows it under the tractor mounted. Mark H.
Alex C
03-03-2005 04:40:02
 Re: 200 lb Front Weight in reply to Willy-N, 03-02-2005 20:36:19
Can the hood still open....I'm not sure about the TO-30 but the TEA20's hood folds out.
Willy-N
03-03-2005 06:46:20
 Re: 200 lb Front Weight in reply to Alex C, 03-03-2005 04:40:02
Yes the Hood still folds forward. When you make the bumper part just open the hood and measure first then make the bumper. Mark H.
gerard
03-03-2005 02:54:26
Message for Willy-N
Looks very professional.
Whilst the front end was off my TE20 I made provision for 4 x 5/8 bolts in the area you've mounted yours with a similar project in mind, but as yet have progressed no further.
I was concerned about flexing without reinforcement fore or aft of the axle pivot box.
Seems from your photo that you have supports running back, but I can't see properly from angle photo is taken.
Could you advise if your setup has rear supports?
Thanks,
Willy-N
03-03-2005 06:49:00
 Re: 200 lb Front Weight in reply to gerard, 03-03-2005 02:54:26
No mind did not have rear suports but it would be real easy to run a couple back to the bell housing area if you wanted to. I will see if I still have some more pictures of it saved. Mark H.
Willy-N
03-03-2005 07:01:46
 Re: 200 lb Front Weight Better Picture in reply to Willy-N, 03-03-2005 06:49:00
third party image
I think the 6" chanel steel was 12 inches wide but not sure now. Mark H.
Willy-N
03-03-2005 07:03:26
 Re: 200 lb Front Weight Better Picture Side View in reply to Willy-N, 03-03-2005 07:01:46
third party image
Here is a side view of it. The Bolts hold the bumper in and you can make a lighter one for a regular bumper. Mark H.
Alex C
03-03-2005 15:49:57
 Re: 200 lb Front Weight Better Picture Side View in reply to Willy-N, 03-03-2005 07:03:26
Thanks Willy....you do nice work
