Well, I made it to work this morning so that must mean that at least part of my driveway is clear.We set a record here yesterday for single day snowfall in March - 27cm and possibly more in outlying areas (I live in an outlying area). And since my driveway is long and exposed to a wide open area, it drifts over in no time. And since I had been using my blade, I already had snowbanks, so I was met with snowdrifts in my driveway that were close to 1 metre deep in places. And it wasn't a nice, light, fluffy snow, either. I started my Ferguson up and because it was plugged in, it stated right away, but something wasn't right. I was getting no response from the throttle. This has never happened before. Just to let you know, I usually keep it covered with a tarp (I currently have nowhere to store it indoors), but I had not covered it when I used it last and it had been exposed to a day of blowing snow. Anyways, it eventually responded, but there was always a delay between adjusting throttle up and the engine responding. Could this be a result of snow blowing in somewhere? I decided I wouldn't try to adjust the spring(?), so I tilted the snowblower back so the attachments were the same height as my riased 3 point hitch and wouldn't you know it, it worked. I was hooked up in about 30 minutes and ready to go. But, by this time it was dark and the wind had died to almost nothing - and what wind there was was blowing right up the driveway. So even if my rear light did work (it dies 2 days ago - I don't know if it's wiring or bulb), there was no wind to remove the snow fog I was creating so I was getting it right in the face. Needless to say, my first pass was a zig zag pattern down the driveway as I bounced from snowbank to snowbank. Then the non-live (or is it live?) PTO ghost appeared and I was contiually bogging down as I created mountains of snow behind my blower. I tried lifting the hitch - which worked to a point - and I tried going forward and backing up into the mountain - which also worked for a while - until I broke a shear pin on the blower shaft. I didn't have a replacement, so I used a nail which lasted about 30 seconds. The 2nd nail lasted about 45 seconds. The next nail (bigger than the 1st 2) lasted about 15 minutes until I overwhelmed the snowblower again and it failed. The pin would also break if the hitch raised the blower too high with the PTO turning (which is why I didn't want to use it without being able to turn the PTO on & off), and after about 6 nails, I had a lane cleared down my driveway and a path cleared to the barn. My wife wasn't too happy when I told her that I had broken several nails where her horses will be walking, so we'll have to keep our eyes open for them come spring time. By this time it was 9:30ish, I hadn't had dinner and I knew there was beer in the fridge, so I called it a night and claimed victory. (I also cut a nice extension cord that was buried under a drift near the house - I was pretty happy when that happened). And I promise you that I did not have a beer until after I shut down my tractor and flopped into a chair, but it does indeed look like I was drunk when I cleared that path. Any thoughts on what is the glitch with my throttle? Also, when I would overwhelm the snowblower, the tractor would begin to die and would have stalled if I let it, but I assume this is due to the weight of the snow and the strain on the PTO. I bought proper shear bolts today and will try to finish the job tonight. Gary (North Bay, Canada)
