Front Blade
TerryMi
03-10-2005 15:48:36
There is a MF front blade on Ebay it is model #1026. The seller is listed from New York. way to far for me to even concider. But I would like to know if anyone has put one of these particular model on a TO 35. This one has hydro lift and angle. So I am thinking the hydraulics might be to much for a TO 35 to handle. Appreciate any thoughts. Terry
George S. in the real NY
03-20-2005 07:29:11
 Re: Front Blade//part 2 in reply to TerryMi, 03-10-2005 15:48:36
Slow morning so I tried and successfully got on ebay home page, entered the item # and lo! up came the page with pix. Interesting there were no bids. Looks to me like it goes on later models of MF. Very similar in design to one I got that goes on Yamnar built JD 750. I'd need to be more sure it will go on a TO series. Worth a look.
03-20-2005 05:13:19
 Re: Front Blade in reply to TerryMi, 03-10-2005 15:48:36
Hi Terry, I am interested in a snow blade setup for my TO35. This computer is too feeble to get into Ebay, gets all confused during down loading, and then sits here blank. I would expect that the under tractor frame has to be special for TO35 as the wheel base is a little longer than the eariler models. Could you tell for sure if the item was spec'ed for the TO35. I might have to find a different way on line. Thanks for info. George
danct
03-11-2005 07:51:31
Terry
another option is to add a pump to the engine and power the blade off of it, you can add a control valve giving you up ,down ,left and right direction ,leaving your hydraulic 3point hitch to use for something like extra weight should you need it,Zane Sherman on the Ford 8N board is a good guy to talk to about this before you do anything.
good luck
Danny
John (UK)
03-11-2005 05:35:02
The TO35 should handle a blade OK. It has pressure of 2500psi and a maximum oil flow of 4.5 gpm. There used to be one made for it and there was even one for the TO/TE series and they worked OK.
Barry from Stirling
03-11-2005 04:33:15
Morning Terry
I put a front blade on my TEA-2085 and use a 12 volt electric winch to raise and lower it. The blade swings from right to left as well. I have to do this manualy. It works great. I will repost a picture under parts and pieces to the left.
TerryMi
03-10-2005 15:50:59
The Ebay item # is 3880546540.
