Front of Transmission
bryan86
03-18-2005 21:49:35
the front cover to my transmission seems to have a littl gap on the left side of the motor. When parked on a hill and trying to start the tracotr fluid comes out of there. Someone told me it is there in case to much fluid is put in the transfer case. IS this true or does the cover have a gap there. Can you buy the cover to replace it or what should I do. IT is the little cover to the front of the transmission right by the engine block. IF anyone can help with this I would greatly appreciate it.
cdmn
03-20-2005 17:23:55
 Re: Front of Transmission in reply to bryan86, 03-18-2005 21:49:35
Is he talking about the access to the starter switch?
bryan86
03-20-2005 15:11:18
Hey John, I was not even thinking when I posted a message. It is for a ferguson te-20. Would you happend to know where to get sheet metal. I need a new hood.
John (UK)
03-21-2005 13:00:29
 Re: Front of Transmission in reply to bryan86, 03-20-2005 15:11:18
Lots of guys forget to tell us what tractor it is. They are so used to working on it they think we know what it is....lol
No complete hood available yet, you can get the 2 grilles and the Tee piece in the middle also the 2 side panels but no top. Maybe you could look around for a decent one from a breakers yard. If you advertise in a mail on here for a used one someone will write in and tell you where to get one. These guys have shopped around and they know the most likely places, but you have to give them some idea of where you live so they know where to send you.
Eric Stevens
03-22-2005 18:48:43
 Re: Front of Transmission in reply to John (UK), 03-21-2005 13:00:29
Not to change the subject but you mentioned you can get the grills and more. Can you get the same for a TO30? If so where? Thank you. Eric
John (UK)
03-23-2005 12:00:21
 Re: Front of Transmission in reply to Eric Stevens, 03-22-2005 18:48:43
Now if you were a member of FENA you would have seen an advert in the March news letter. I was lucky and Paul sent me a copy so that's how I know....lol
the people who are advertising THEM are : -
NOLT'S EQUIPMENT
403 CENTREVILLE ROAD
NEWVILLE, PA 17214
PHONE (717) 776-6242
$150 PLUS SHIPPING and they are all steel.
hope you get fixed up ok.
Eric Stevens
03-23-2005 17:27:21
 Re: Front of Transmission in reply to John (UK), 03-23-2005 12:00:21
Thanks John. I will call these folks and get the hood. I have read many of these notes and saw one that said there is a latch on the hood. Is that correct. If so, mine is missing. Also, I do a lot of work in uneven terrain and have cut two lower radiator hoses where I belive the frame raises and pinches the hose. Do you have a fix for that other than to weld a stop on the axle? Thank you for your time and attention. Eric
John UK
03-24-2005 04:35:35
 Re: Front of Transmission in reply to Eric Stevens, 03-23-2005 17:27:21
I have replied to your email address as I needed to send a parts list for you to look at. That will be leaving here in the next 30 mins.
Eric Stevens
03-24-2005 19:53:52
 Re: Front of Transmission in reply to John UK, 03-24-2005 04:35:35
Thank you....Eric
John (UK)
03-19-2005 10:48:01
well normally there isn't a gap but its quite possible its been damaged. It will let any oil out that gets in there which can only be good. It would help us if you told us what tractor model you had so we don't have to guess and maybe we could give a more positive answer.
