to30 clutch replacement
badboti
03-29-2005 16:49:26
where is a good place to buy a clutch kit for this, its a 1952 to30, i researched a little and have seen to different models for this. also what is the easiest way to replace this, i might have to do it in a dirt floor barn but might try to get it to a garage with cement to make it easier. thanks, chris
John (UK)
03-30-2005 11:18:11
 Re: to30 clutch replacement in reply to badboti, 03-29-2005 16:49:26
Just remember the large side of the clutch plate hub goes towards the gearbox.
gshadel
03-30-2005 05:05:32
Done the tractor split on gravel floor before. Not to bad. Use nice wide, heavy piece of wood under a jack when you support the tranny end so it doesn't sink into the ground. I used an engine hoist on wheels, rolled it on a couple 2X8's to pull the engine away from the tranny.
I think I got my new pressure plate off this web site, but there are several other tractor parts sites, and a local Massey dealer probably would have parts also.
As far as which clutch model you have, I don't know, but I thought the 9" Rockford clutch was the most common one on late '20's and 30's. Jerry is right get a manual. I think that clutch disk will slide on either way, but only one way is the right way.
Jerry/MT
03-29-2005 19:08:56
You'll have to split the tractor which is not to difficult but there are some things to watch for, like putting a 2x4 between the block and the front axle carrier so that the engine doesn't rotate about the front axle pivot pin. Get a factory manual It has a good explanation on clutch replacement. As far as parts, shop around and look at the folks on the left side of this page. Clutches are not hard to find.
