Ferguson Model?
Gary Alford
04-18-2005 06:01:38
Pardon my ignorance as I have no past experience with these tractors. The plate on the dash reads TO-10-3461 and imprinted on the steering houseing it has TO 3550. This has a 4 cyl. gas continental motor Z-129 4spd trans. What model is it? Also it has a 12 volt generator with a positive gnd. is this correct?
phil(va)
04-18-2005 13:14:07
 Re: Ferguson Model? in reply to Gary Alford, 04-18-2005 06:01:38
Usually when they were converted to 12 volts they were also converted to negative ground. I have only seen one other one that was converted to 12 volts positive and that one didn't charge the battery correctly. As John said they were originally six volts positive. Not sure why the person who converted it didn't make it negative. Check if coil and voltage regulator are 12 volts. Starter doesn't care. Does ammeter show positive charge of about 3-5 amps? Put volt meter on battery when running and see what the charge is. should be about 14 volts.
M Creech
04-28-2005 05:16:18
 Re: Ferguson Model? in reply to phil(va), 04-18-2005 13:14:07
I have a to30 ferguson with a front bucket attch.
i have used it for two years .but a crank bearing
turned and the motor is locked up . there is no plates or numbers on tractor except to30 on different housings . can anyone tell me how to
find out what year it might be or what kind of motor it has
it has a 6 volt elec system
4 cly gas motor
brake pedals come from the back
hope to fix it soon 2 grandkids think its great !!
Gary Alford
04-19-2005 05:42:30
Thanks for the info. Phil,and no it wasn't chargeing.
John(UK)
04-18-2005 06:35:37
The serial number you give (TO103461) is a 1953 TO30, the other number is cast into the part and that is just a casting number for the steering column housing. It looks as though it has been converted to 12volt as they were 6 volts originally, but from your point it will be much better. All the TO20's and 30's were 4 speed plus reverse. No need to be excused for asking a question, that is what this site is all about...just ask if you don't know, anytime.
Gary Alford
04-19-2005 05:45:01
 Re: Ferguson Model? in reply to John(UK), 04-18-2005 06:35:37
Thanks John even the owner didn't know what he had.
