TO-20 losing power
bigjon
04-20-2005 14:53:32
i have a TO-20, runs exelent, but as soon as i try to work it it hase no power, at all, thought it might be the governer but i really dont have a clue. like i said runs great but when i try to work it it has nothing. please help
Jerry/MT
04-20-2005 18:15:37
 Re: TO-20 losing power in reply to bigjon, 04-20-2005 14:53:32
Check to make sure that you have fuel going to the carburetor in sufficient quantity. With the tank valve at the sediment bowl open and a big coffee can in hand, remove the bolt on the bottom of the carburetor. Fuel should come out of there like a cow peein' on a flat rock. If it doesn't, check the fuel filters;there's one in the fuel line elbow at the carb and one above the sediment bowl at the tank. If it does come out in copius quantities suspect float level in the carb or clogged jet, etc. But before you take the carb off, check to make sure that you don't have a clogged air filter. Remove the rubber hose connection between the airfilter tube and the carb so that the carb is supplied with air that doesn't come from the filter. Start the tractor and see if you have the same problem. If the problem goes away, remove the airfilter and clean it thoroughly.
Before doing any thing to the carb check the ignition system to make sure that you have a nice hot bluish spark and check the timing at idle to make sure it is per the spec. Also check the advance mechanism by advancing the throttle the timing should also advance. If any of these things don't check out, make sure you correct them and try the tractor out again. It's important to do these things systematically and check after each change or adjustment to see if you have fixed the problem. You can then nail down what has caused the lack of power.
hope this helps you.
bigjon
04-20-2005 18:45:05
 Re: TO-20 losing power in reply to Jerry/MT, 04-20-2005 18:15:37
thanks alot, ill get to work on it this weekend and see what i can figure out, thanks again, boy this realy means alot, it is great to be able to talk to people like this
John(UK)
04-21-2005 11:27:28
 Re: TO-20 losing power in reply to bigjon, 04-20-2005 18:45:05
If you need information on how to set the governor or the timing, mail me at: -
fergusontractors at tiscali dot co dot uk
and tell me what you need and what the tractor model is.
