engine missing at high idle and under load
badboti
04-27-2005 16:32:48
notice while mowing the engine on the to30 was starting miss. i shut off pto shut off tractor, pulled #4 plug, looks oily, pulled #3 looks brownish color. put plugs back in fire it up and listen to the motor sounds like missing in #4 pull plug wire the noise stops, put it back on it returns, shut tractor off switch #3 and 4 plugs and fire it up runs fine finish mowing its missing again, didnt pull the plug again yet though, what is causing this? how can i fix. thanks, chris
Ray,IN
04-27-2005 18:56:15
 Re: engine missing at high idle and under load in reply to badboti, 04-27-2005 16:32:48
First, run a compression test. The correct method is to shut off gas, remove all spark plugs, and open throttle completely before testing. Then test each cylinder as is; next squirt a teaspoon of oil in each cylinder and test again to get an idea of the condition of the rings. All cylinder test results should be withing 10% of each other, the actual pressure is secondary. Spark plugs fire best under pressure, if #4 is quite low or zero due to a valve stuck open, the plug will not fire as reliably.
badboti
04-28-2005 16:22:57
 Re: engine missing at high idle and under load in reply to Ray,IN, 04-27-2005 18:56:15
went out and did a compression test, here are the results, 80-90-65-85 with oil added 90-105-80-95did check firing order yet though, the 65 kind of scars me, should i be planning on rebuilding soon?
Ray,IN
04-28-2005 20:57:40
 Re: engine missing at high idle and under load in reply to badboti, 04-28-2005 16:22:57
It appears #3 cyl is a concern, however you said #4 cyl is where you have determined the miss is occuring. What was the result of switching #3-4 plugs? Since the dry/wet compression test indicates #4 cyl has good compression the rings are unlikely; that leaves leaking intake valve guides as the probable source of oily sparkplug. Back to #3. Borrow a bore inspection tool from AutoZone and inspect the cylinder walls for scoring, if the walls are smooth with no evidence of scoring, I would leave it alone as long as it doesn't get worse or begin making unusual noises.
gshadel
04-28-2005 07:35:20
Ray's right, if the noise stops when you pull the plug wire... might be a valve problem. Compression test should show that. I recommend switching your wires around and making sure they are in the right firing order. Firing order is 1,3,4,2
Also pull your distributor cap and make sure it is clean inside. If you have disributor bushing wear (like a lot of these old TO's), the rotor will grind into the cap contacts over time and pepper the inside of the cap with fine metal shavings, which makes your TO run like crap after a while.
