No Charge in Battery
Oregon Will
05-05-2005 08:24:13
I have a TO 35 and the battery seems to lose its charge. I have charged it up and it will start the tractor but if I shut the tractor down it won't crank it over without a jump. How can I tell if the problem is a bad battery of a weak generator? The tractor runs fine once it is started.
Jeff-oh
05-05-2005 09:37:45
 Re: No Charge in Battery in reply to Oregon Will, 05-05-2005 08:24:13
You can take the battery to an auto parts store. Many have battery testers and will do it for free.
h wilson
05-05-2005 11:14:15
 Re: No Charge in Battery in reply to Jeff-oh, 05-05-2005 09:37:45
I had the same problem on my TO-20. It turn out to be the points stuck in the voltage regulator. I took it apart and manually released the points. I have had no problem since...(did I mention this was a fairly new volt reg)
Jim W
05-06-2005 13:02:24
 Re: No Charge in Battery in reply to h wilson, 05-05-2005 11:14:15
Once it's started try disconnecting one of the battery cables. If it quits running immediately then it's running only from the battery and the charging system is defective.
Jim
