need tach for to-35...also running hot???
770
05-28-2005 09:01:02
I need a tach for a 1956 to-35. Good used working??? Also, when I run tractor hard...Exhaust manifold will have a dull glow. The tractor runs awesome and starts easy and the temp on the gauge never gets too high....Any input??? Thank you in advance.....
Ter
05-30-2005 06:06:56
 Re: need tach for to-35...also running hot??? in reply to 770, 05-28-2005 09:01:02
Do you have a temperature gauge? If Not you should get one, to make sure she does not overheat on you.
770
05-30-2005 08:39:58
 Re: need tach for to-35...also running hot??? in reply to Ter, 05-30-2005 06:06:56
I installed a new gauge and it stays right around 170-180 degrees.
Ter
05-30-2005 10:43:45
 Re: need tach for to-35...also running hot??? in reply to 770, 05-30-2005 08:39:58
I am sure that is within range, hope others will have some input on that. My TO 35 rarely gets obove 140, but than I rarely over work mine. When it is hot and I am chopping tall grass I will stop every hour or hour and half to let her cool down. Terry
John(UK)
05-29-2005 04:12:31
It's not unusual for the exhaust manifold to have a dull glow as they do get quite hot. As long as the engine has plenty of power it would appear to be ok and not needing any alterations.
