12v conversion
chris sweetland
06-16-2005 16:55:01
i want to convert my 48 to-20 to 12 volt i do not want to buy a kit as they cost alot and i have a few good gm and ford alternators what elis do i need and how do i make the switch also will i have to replace my starter to 12 volts? it is week and i have a few that may work buy i havent looked at them
John(UK)
06-17-2005 13:12:19
 Re: 12v conversion in reply to chris sweetland, 06-16-2005 16:55:01
If you need wiring diagram for this conversion, mail me at:-
fergusontractors at tiscali dot co dot uk
just tell me what type of alternator you intend to use (single wire or normal type)
danct
06-17-2005 08:34:29
Chris ,
anything on the tractor now that is 6 volts will need to be changed to 12 volt like the lite bulbs for instance ,the coil you can get away with using a resistor in series with the hot lead feeding it ,the starter will be ok provided it is good now,the big thing will be the mounting of the alternator,use secure brackets as you dont want it to fly off,also you should have a pully that can use the exesting belt ,or at least one as thick,hope this helps
good luck
Danny
Archie
06-16-2005 18:23:59
6 volt starter works better on 12 volt.Just donot crank it for a really long time.
chris sweetland
06-17-2005 04:52:05
 Re: 12v conversion in reply to Archie , 06-16-2005 18:23:59
but is there anything i need to change to make it work on 12 volts besides the alternator
kyharold
06-17-2005 08:33:56
 Re: 12v conversion in reply to chris sweetland, 06-17-2005 04:52:05
battery, coil and if your alternator doesn't have a built in regulator then you will need a voltage regulator.
