Red dash light on a TO-20
David Gabler
06-19-2005 21:01:09
What does the red dash light mean? I recently had the tractor serviced and now it comes on. Reading this post, Link it seems that the possibly indicates your alternator is not working? TO-20, 12v.
jeremy g
06-22-2005 16:21:58
 Re: Red dash light on a TO-20 in reply to David Gabler, 06-19-2005 21:01:09
were can i find one of those lights for my 20 been looking but i cant find them around. thanks
zippy4554
06-20-2005 07:16:39
  Red dash light on a TO-20...meaning in reply to David Gabler, 06-19-2005 21:01:09
The red light means the system is not charging. This could be for any of a number of reasons, engine running too slow, regulator not working, generator not providing a charge etc.
In your case with 12V, there may be other reasons. If it is now negative ground, I suspect the red light will be on all the time. I guess you'd need an ammeter hooked up properly to see what was going on.
Kiwi
02-04-2006 18:38:10
 Re: Red dash light on a TO-20...meaning in reply to zippy4554, 06-20-2005 07:16:39
I need to replace the bulb in the Dash Light of my TEA-20.(12v system)
Can anybody out there give the correct spec. for this bulb,ie. voltage, wattage and fitting type, etc.
Thank you in anticipation,
Ray
Jeff-oh
06-20-2005 07:13:50
The red light, when wired and working propperly, indicates that the battery is not being charged.
