Aric-tractor id
Bill Long
06-08-2000 14:52:39
Aric-Post the serial numbers off the dash plate and motor plate and someone will identify. Also,you can check the serial numbers on this website. (I was not able to post a normal follow-up)
Aric
06-09-2000 10:15:40
 Re: Aric-tractor id in reply to Bill Long, 06-08-2000 14:52:39
Bill The dash reads TO-3744.
What I can make out on the engine plate is:
7120 103816.
I'll check out the serial numbers on this forum as you suggested to also decifer it.
Thanks alot Bill.
Aric
Chuck
06-10-2000 07:57:30
 Re: Re: Aric-tractor id in reply to Aric, 06-09-2000 10:15:40
Aric,
From what you posted, it seems you have a 1949 TO-20.
I wonder if that engine # (7120 103816) could actually be Z120 103816.
That would make a little more sense, indicating a Continental Z120 engine which was the one used on the TO-20.
If you go to the left hand column and click on "Tractor Shed", it will take you to a number of excellent sites for your tractor.
Have fun.
Chuck
