Ferguson value
Alan
06-08-2000 16:21:18
We have a early 50s TO-20 or TO-30 (I have to look up the numbers again, I forgot!) Needs tires wheels are ok. Also needs a card, It has a Marvel Shebler on it ( or at least it did before I decided to rebuilt it and the cats knocked the fool thing off the shelf scatering the parts to the four corners of the earth)! Also needs the exhaust manifold welded. it had been repainted about 20 years, and is still in pretty good shape. The needle value was screwed up in the carb and it just sort of sputtered along. Still spins just needs the carb put back on it. I'm just wondering what the tractor is worth. Is $1,500 too much as is how about $1,000. What if I put a carb on it and some good tires? $2,500-$2,000? How far out of line am I?
Phil
06-19-2000 06:33:32
 Re: Ferguson value in reply to Alan, 06-08-2000 16:21:18
Serial number is very important. It makes a difference, at least it does to me, if it is a TO20 or a 30. I will definitely pay more for the 30.
Dave R
06-13-2000 09:26:15
It depends somewhat on the area your in. With
no carb and bad rubber, the price may be a little
low. My guess would be somewhere from 700 to 1200. (U.S.) If the machine can be made to run
at all with a replacement carb your price should
jump considerably. Maybe 1200 to 1800. Get it running well and put some passable rubber on it
and it should be in the 2000 and up range.
Just a guess
Dave R
