Model Identification
Bob from Minnip
06-30-2005 00:14:25
I have a MF tractor with engine number L276 3711 2600. The gear box number is 997-79-M2. The rear axle has a number 899473M1. Rear tires are 18.4 x 30. There is a plate on the manifold but all of the information has been obliterated. It was sold at auction as a 165 but a friend who knows Masseys fairly well is sure it isn't a 165. Does anybody know what model and year this might be? It is fitted with a front end loader and since it was serviced recently, the front end loader won't lift. I am wondering if the serviceman used hydraulic oil which may not be viscous enough for the pump. A repairman says the hydraulic pump is worn out and wants a few thousand dollars to repair/replace it. I believe that if there is a hydraulic filter inside the gearbox, how would he know if the pump was worn out or if it was a blocked filter. Hence the need to know the model etc. Any ideas or advice gratefully accepted.
Bob from Minnipa, Sth Australia
