MF TO-35
5-7 shepherd
07-08-2005 21:25:16
I am need of some advise, I have a 1955 TO-35 with a cracked engine block ( not repairable ).
What are my options? Can I replace the Continental Z134 Engine with a rebuilt model. Can I upgrade the engine with a larger size. Where can I obtain rebuilt engines. Any help or suggestions would be greatly appreciated.
T
07-10-2005 12:29:15
 Re: MF TO-35 in reply to 5-7 shepherd, 07-08-2005 21:25:16
I think I have heard or read of someone replacing the motor on a european TE35 with a 3 cylinder Perkins diesel from some combine harvester. The motor was similar to those in in later MF35x. I do'nt know if it fitted readily.
John (UK)
07-11-2005 13:10:18
 Re: MF TO-35 in reply to T, 07-10-2005 12:29:15
Your information is totally misleading and there is no TE35. You can fit a Perkins 3 cylinder engine (3-152) in an FE35 as that was called the MF35 and painted a different colour later and it is more or less the same tractor as the TO35.
Ter
07-09-2005 13:41:55
You say the cracked engine is not repairable. I have not had one before but have seen many listing is this forum, from those that have rebuilt their cracked blocks with no problem. It is my understanding that cracked blocks are quite common with the fergusons. I am sure someone will respond with the info you.
