TEA-2085 and a Bushhog
Barry from Stir
07-18-2005 07:17:10
Morning Everyone
Im on vacation again in couple of weeks, and Im planning on cleaning up a few area"s around my house with the bushhog. I know that this topic has been talked about enough in here over the last few years, but I want to have someone explain it to me a bit more clearly. Here goes. The bushhog Im using mounts on the back of my TEA-2085 like any other 3-point hitch implement. The problem is that the front of the hog is quite low compared to the back of the mower. In other words it doesnt sit level. How can I correct this? Is there a way to fix this so it stays level. I have read about Limiter chains, am I on the right track here. Can someone explain to me what I need to do, point by point. Thanks in advance as always,,, Barry
Rod in Smiths Falls, ON,
07-18-2005 17:45:29
 Re: TEA-2085 and a Bushhog in reply to Barry from Stirling, 07-18-2005 07:17:10
On the TEA I inherited there is a piece of 1 by 3 channel steel under the upper arms and pushing down on the coil spring. The whole thing is secured by u-bolts. It definitely keeps the arms from hanging down too far.
A 2X4 across above the coil spring might work as an experiment...
John (UK)
07-18-2005 11:25:59
This is the email from Marlowe that is referred to:-
Posted by marlowe on June 23, 2004 at 16:01:09 from (209.103.204.81):
In Reply to: position control...chains?? posted by mr chapp on June 23, 2004 at 06:16:49:
dear mister chapp. i have sold and serviced hogs for years and see this all the time. PLEASE don't take this wrong but it's a real common mistake that they are not beening mounted right.i know what your thinking how hard is it to put a hog on a tractor and go cut some grass? but!! your hog has a tail wheel right? your tractor has 2 lower lift arms right? set your hog on a 4x4 so it is level lower your tail wheel so it's on the ground. now put your tractor on but[[[[ DON'T]]] hook up the PTO with tractor running put the 3pt. control lever in the middle of the range and turn your top link so it will get longer and you will feel you 3pt. raise just a little and the stop but when you make the top link long it will raise a little more that because the control piston under the set is being pushed in and that makes you 3pt. lift untill the pressure is releasted.with a little fine tuning and a little setting of the tail wheel up or down for the height of cut you want your hog will cut at the height you want. if you have ANY questions call me i will help you set it right 1-920-446-3296 your hog should not be hanging on the tractor when your cutting but rideing on the tail wheel and the 3pt. at a set height and that is controled by your top link. good luck and if you need help call
Barry I have emailed you separately because this is for a TO20 and you have a TO35 which operates differently..John
Matt-in-KS
07-18-2005 10:35:18
Take a look at this discussion. It should answer all of your questions.
http://www.ytmag.com/ferg/messages/34754.html
Gene Stevens
07-18-2005 08:56:59
If you make the top link longer you will push the top of the mower back thus raising the front. Place a 4X4 under the front...hook up the top link and lenghten it until the front of the mower starts to raise. Make fine adjustments in the field. Gene
Jeff-oh
07-18-2005 08:29:24
You can do a search on bush hog set-up orgionally posted by Marlow.
But to adjust the height of the bush hog, adjust the length of your top link. Shortening the top link will raise the front of the mower.
Jeff
John (UK)
07-18-2005 11:20:45
 Re: TEA-2085 and a Bushhog in reply to Jeff-oh, 07-18-2005 08:29:24
Lengthening the top link, that should read, will lift the front of the mower. A mere slip of the keyboard.(I do it all the time)
