Ford - Ferguson parts interchange ????
Alberta Mike
07-18-2005 09:17:43
I know the engines on the Ford N series and the little Fergies are completely different, but I'm wondering as to whether any other mechanical parts on the two tractors interchange with each other? Things like hydraulics (inside and outside hardware), driveline components, steering, axles, etc.
Mike Mohrhauser
07-20-2005 12:01:08
 Re: Ford - Ferguson parts interchange ???? in reply to Alberta Mike, 07-18-2005 09:17:43
If you get a 1952-1954 Parts Manual for the TO-30 it will list all of the parts that will interchange between the 9N, 2N, TO-20,TO-30,TE-20 and the TEA-20. I have found it to be a virtual gold mine along with a Dennis Carpenter Ford Tractor catalog. Just a couple weeks ago a got a tail light bracket for my TO-30 that was identical to the old one.
Mike M.
John (Ont)
07-19-2005 16:11:25
Mike:
The Parts book that I have, original Harry Ferguson, Inc. November 1952 lists all the parts and Part #'s that are common to the Ford 9N-2N and the Ferguson models.
Eric Stevens
07-18-2005 13:48:10
I had to rebuid my hydraulic pump on my TO30 and found that Ford 9N parts fit. Just needed O-rings or gaskets on the end caps, can't remember which I used. Works fine though. Eric
John (UK)
07-18-2005 11:17:45
Some of the hydraulic stuff interchanges
Ray,IN
07-19-2005 12:30:23
 Re: Ford - Ferguson parts interchange ???? in reply to John (UK), 07-18-2005 11:17:45
Hi Mike! Many/most of the parts will interchange, except the engine and transmission. In fact the hand clutch on my TO30 is originally made for Ford tractors. The Hyd relief valve is different though, the Ford is set at 1900lbs and the Ferguson at 2200lbs. They are still interchangable.
