t0-30 damper
Booger
07-18-2005 18:14:16
Hi; I am pulling out my crank on my T0-30. What is the best way to get the damper pulley out? Will new main and rod bearings reduce end play?
Little Dave
07-19-2005 20:51:44
 Re: t0-30 damper in reply to Booger, 07-18-2005 18:14:16
Booger The brass thrust bearings are on the number one main of the Z-129 engine. The front one is pinned to the front of the block and the other on the rear of the main is free. I had my crankshaft welded and reground back to standard size and used a flanged number one main and the brass washer still pinned to the block on the front. You will have to shim the end play and the book calls for .003" to .007". The job with shimming is putting it together and check then tear it down to add the shims. I hit mine with a dial indicator second try. Have fun ! Dave
Jerry/MT
07-19-2005 15:35:49
To remove the crankshaft pulley, I used a three pronged gear puller. I believe the crankshaft thrust is taken by a thrust washer pack on the front of the crankshaft as well as one of the main bearings. It's in the shop manual and mine isn't handy right now.
