How to time my engine
nitro
08-01-2005 10:22:31
Can anyone explain how to time my Z134 MH-50 tractor. After about six months rebuilding her i finnaly fired her up yesterday. She runs good but i was wanting to put a timming light on it but i didnt know if im to shoot the light through the hole on the back of the engine or somewhere else? please let me know how and what i can do to get her timed right and also do i need to do anything special to break the engine in. THX
Jerry/MT
08-02-2005 14:47:18
 Re: How to time my engine in reply to nitro, 08-01-2005 10:22:31
I'm not sure where the timing marks are on the Continental Z134 but if you have a Shop Manual it'll tell you. If you have a hole in the back of the block, shine the timing light on it and you should se some marks on the flywheel if that's where the timing marks are at. Usually there is a speed at which you set the initial timimg. On my TO-30 it's 400 rpm. All you do is set the initial timing speed, shine the light on the timing mark and note the timing (for example: 6 degrees BTDC (Before Top Dead Center)) If the timing should be 5 degrees BTDC, loosen the hold down bolt on the distributor and rotate it in the direction of rotation of the rotor til the timing mark is at 5 degrees BTDC. If it should be 7 degrees BTDC, rotate the distributor opposite the direction of rotation til the timing mark is on 7 degrees BTDC
