Ferguson toplink?
lonestarjeff
08-08-2005 20:58:41
I have an old toplink I'm trying to restore. It's similar to a modern type(threaded @ each end)& has a steel ring, instead of a lever, at the midpoint. One of the ball ends is stamped "forged", the other is stamped "made in england".
Did Ferguson offer such a thing?
Jeff
P.S. Sorry, I forgot to snap a pic while I was @ the farm.
John (UK)
08-09-2005 14:29:55
 Re: Ferguson top link? in reply to lonestarjeff, 08-08-2005 20:58:41
No Ferguson didn't offer that...it sounds like a Tamkin top link to me, this was possibly the first screw type top link we had in the UK.
Hamish Fae Perth
08-09-2005 07:15:36
 Re: Ferguson toplink? in reply to lonestarjeff, 08-08-2005 20:58:41
What you have sounds like the adjustable, screw type, top link, that was supplied with the Ferguson Blade Terracer,B-FE-20, to allow easy blade pitch adjustment. I think it was also sold as a Ferguson TE accessory.
If yours is a genuine Ferguson item it will have "increase" and "decrease" stamped on the steel ring.
Hamish
Crem
08-09-2005 18:48:19
 Re: Ferguson toplink? in reply to Hamish Fae Perth, 08-09-2005 07:15:36
We had a toplink like that and it came with a blade that was probably bought in the forties. We used it on a Ford Ferguson which I am not sure if it was a 9N or 2N. The blade is long gone, but I still have the toplink which is very rusted.
lonestarjeff
08-09-2005 07:28:34
One end is free & loose, the other is frozen solid(the screw & the ball). I'm soaking it w/ PB now, if that doesn't work I'll try a little h & h.
My next trip to the farm I'll clean it up & see if it's stamped as you say. Thanks for the info.
Jeff
Peter uk
08-09-2005 00:12:19
Jeff,
The original Ferguson top link consisted of two lengths of flat bar, slotted at each end to allow for lengthening/shortening, which was bolted together by 2 bolts. What you have might be a later Massey Ferguson top link.
lonestarjeff
08-09-2005 07:16:45
 Re: Ferguson toplink? in reply to Peter uk, 08-09-2005 00:12:19
The flat-bar version you describe sounds just like the original toplink from Ford that came w/ my 8N.
Jeff
steveormary
08-09-2005 10:22:57
 Re: Ferguson toplink? in reply to lonestarjeff, 08-09-2005 07:16:45
A flat bar top link came with the new TE-20 we bought way back in 1948. Dont know if it was stamped Ford or Ferguson.
steveormary
lonestarjeff
08-09-2005 17:04:43
 Re: Ferguson toplink? in reply to steveormary, 08-09-2005 10:22:57
I haven't noticed a stamp on ours either, have to take a closer look.
Jeff
