Oil Seal
Albert Betts
08-11-2005 18:43:54
Is there a temp oil seal that replaces 195 557 M1 I understand that the replacement of the OEM seal you have to heat the old seal up to get it off and on,,,,, ,my brake pads are really saturated with oil,,,,, ,thanks Albert
John (UK)
08-13-2005 07:16:25
 Re: Oil Seal in reply to Albert Betts, 08-11-2005 18:43:54
Albert I have been trying to contact you as I cant send the information you asked for a while ago. I have left a message on here if you look back a few days. You can get "Sure Seals" for your problem, they fit on the axle-shaft next to the bearing and they keep the oil from the transmission from leaking into the brake drum. They are quite inexpensive too. can you please contact me at :-
fergusontractors at tiscali dot co dot uk
so I can send this information you requested.
dennis p in ohio
08-12-2005 07:42:25
I just had mine done. I did not attempt it myself because there is a heat shrunk collar on the axle that has to be removed and replaced.
My local Massey Ferguson dealer did it for me and I think it cost no more than about $25 USD. If you want to try it yourself, you'll have to have an oxy-acetylene torch and follow the directions in the manual. The seal itself is not expensive and is readily available, even on this website.
Good luck and let us know how you do with it.
