Engine speed
danny hill
07-03-2000 05:46:28
problem with ferguson. idles great, but tries to run wide open when gas lever is barely moved forward. is this governor problem or carb.? govenor does not move or respond reguardless of tractor speed.
Danny
07-05-2000 10:11:38
 Re: Re: engine speed in reply to Neal(IN), 07-05-2000 04:54:58
neal, your comment on the linkage being out of adjustment was on the money. I adjusted the linkage the afternoon after my e-mail. This morning I read your reply. All the moves I made were exactly as you called them. Just wanted you to know you were right on with your suggestions. Danny.
Neal(IN)
07-07-2000 09:23:19
 Re: Re: Re: engine speed in reply to Danny, 07-05-2000 10:11:38
Danny
Glad your problem was a simple one.
Where are you located?
Neal
danny
07-07-2000 13:59:38
 Re: Re: Re: Re: engine speed in reply to Neal(IN), 07-07-2000 09:23:19
located middle Tn.
SandyB@TN
07-03-2000 18:40:11
 Re: engine speed in reply to danny hill, 07-03-2000 05:46:28
Danny,
I hope you have the original or I&T shop manual.
You definitely have governor problems. Sounds like it's stuck in one position. Check all the linkages to make sure there isn't a bind in them. The original shop manual goes into detail on rebuilding and adjusting the governor. The I&T is somewhat vague and vague is not what you want. Hope this points you in the right direction.
Sandy
