Ferguson to35 Thermostat
Chester2
08-26-2005 16:22:41
Can anyone tell me where I can buy a new thermostat for my Ferguson TO 35? And once I get one, how hard will it be to replace the old with the new. Im not a mechanic in any way but perhaps I could do this myself. Thanks
phil(va)
08-27-2005 09:59:45
 Re: Ferguson to35 Thermostat in reply to Chester2, 08-26-2005 16:22:41
NAPA does have them, and they have a flange, unlike the one for the TO-30. I believe this thermostat is used in some foreign cars, like some models of Mercedes, so they should be easy to find at most NAPA stores.
Chester2
08-28-2005 07:51:49
 Re: Ferguson to35 Thermostat in reply to phil(va), 08-27-2005 09:59:45
Thanks, we have a napa here, Ill check it out. thanks again.
TO35
08-26-2005 17:52:14
Your local massey dealer or napa,Gas or Diesel? If I recall I bought my last one from napa. Not to bad a job to replace, drain antifreeze/coolant remove top hose the the two bolts holding the housing in place, the remove the thermostat and reinstall in the reverse order. They are for the most part just like an automoblie and most mount the same way...some are located in the top hose instead of under the housing. be sure to install the thermostat so it points to the raditor it should be marked.....
have a nice day
TO35
