Jumping Fergies!!
NGolgerth
08-29-2005 20:33:31
I have just bought and old grey fergy.
I have been just bought a carryall and started play with it and I have a small
problem .( Well I hope it is)
When I ues the hyd to lift the carryall and when it get to the full hight the
whole tractor starts jumping and with any weight on it it keeps jumping.
What I have noticed is when you push the clutch in it stops.
Can you suggest what maybe wrong.
Hope you can help me.
Norman
john (UK)
08-30-2005 07:03:09
 Re: Jumping Fergies!! in reply to NGolgerth, 08-29-2005 20:33:31
Check if there is any play in the Control Spring at the back of the seat, you should be just able to turn it with the carry-all raised if there is slack in this spring this can cause the problem you have and you would need to adjust it but it may be seized up now, if you need more info on this email me at:-
fergusontractors at tiscali dot co dot uk and explain your problem to me again on there. You could try for now to stop it by moving the lift control lever slightly forward towards the drop position, that may help.
