Brake confusion
scott lamberson
07-09-2000 22:29:31
I recently overhauled the brakes on my 1950 to30. I had the shoes relined and the drums turned. Also the axle seals were leaking so I replaced them too. Any way the problem is that when I depress the brake lever to control both back brakes, the independent brake levers on each side go up instead of going down like they should if you were using them independent from one another. I have checked and double checked and can not find anything wrong. what have I missed?? If any one can point me in the right direction I would really appreciate it, scott
Pete Tatam
07-10-2000 12:27:53
 Re: brake confusion in reply to scott lamberson, 07-09-2000 22:29:31
Scott, I dont think youve done anything wrong. If the brake linkage on a TO 30 is similar to that on a TE 20, and I believe it is, what happens is when you depress the brake pedal it pulls forward the cam which in turn raises the independant brake pedal. It happens on my TEF.
Dont worry, theres no problem.
Regards, Pete.
